Tools & Capabilities
*Indicates remote operation is available
Nanofabrication and Devices
More Info- 2D Heterostructure Transfer System in Glove Box
- Post-Processing
- Deposition
- AJA Dielectric Sputtering System*
- AJA Metal Sputtering System*
- AJA Oxide Sputtering, 3 inch targets*
- AJA Sputtering, 2 inch targets*
- AMAT P5000 Deposition Tool (SiNx, SiO2, TEOS Films)
- Angstrom Sputtering System
- Angstrom Engineering Thermal Evaporator
- Atomic Layer Deposition (Arradiance Gemstar)*
- Cressington sputter coater 108auto
- Integrated UV-Ozone Cleaner and Molecular Vapor Coater (Nanonex Ultra-100)
- Lambda Microwave Plasma CVD System: nanocrystalline diamond deposition*
- Oxford Plasmalab 100 Inductively Coupled Plasma Enhanced Chemical Vapor Deposition
- SDS6K Diamond MPCVD System
- Temescal FC2000 Electron Beam Evaporator
- Veeco Fiji G2 PEALD
- Veeco S200 Atomic Layer Deposition (ALD) System
- Inspection and Metrology
- Bruker FastScan Atomic Force Microscopy (AFM)*
- Filmetrics f40 Thin Film Analizer*
- Four Point Probe*
- K-Space Stress Gauge*
- Keyence 3D Laser Scanning Confocal Microscope, VK-X1000*
- Laser Confocal Microscope OLS4100
- Optical Microscope: Olympus MX-61
- RC2 Ellipsometer JA Woollam*
- Surface Profiler
- ThermoFisher Field-Emission Scanning Electron Microscope Verios 5 UC*
- UVISEL Spectroscopic Ellipsometer: Horiba Jobin Yvon
- Scanning Electron Microscope VEGA 3 (tungsten filament)
- Thin film transfer system
- Lithography
- Electron Beam Lithography System: JEOL 8100FS*
- Electrostatic Wafer Bonder
- Heidelberg MLA 150 Maskless Lithography*
- Laser Pattern Generator (Microtech LW405, direct write optical lithography)
- MLA 150 Maskless Lithography System Field Alignment
- NxQ8008M Contact Aligner*
- ThermoFisher Helios Hydra 5 Plasma Focused Ion Beam Milling*
- Wafer priming oven: YES-TA series
- Wet Chemistry
- Electroplating (Au, Cu, Fe, Ni, Pt)
- Selective Wet Chemical Etching
- Dry Etching
- Hydrofluoric acid vapor etcher
- ONTOS Atmospheric Plasma Surface Treatment System
- Oxford PlasmaPro 100 Cobra, RIE-ICP and ALE
- PlasmaTherm Deep Reactive Ion Etcher (DRIE) for silicon
- RIE Oxford ICP etcher (6-inch)
- RIE March CS-1701, Fluorine Chamber
- RIE Oxford PlasmaLab 100, Chlorine Chamber
- RIE Oxford PlasmaLab 100, Fluorine Chamber
- SAMCO RIE-10NR
- SPTS uEtch HF Vapor Release tool
- Xactix X4 xenon difluoride etcher
- Wear/Friction Measurements
- Multifunctional Tribometer (controlled environment)*
- Sonotek Ultrasonic Spray Coating System
- TEM Picoindenter, in situ (PI-95)
- Ultralow Temperature/Strong Magnetic Field Measurements*
- AMI Superconductor Vector Magnet
- BlueFors LD400 Dilution Refrigerator System
- Adiabatic Demagnetization Refrigerator (ADR)*
- Atomic Force Microscope Cypher L Model in Glove Box
- Renishaw Raman microscope in Glove Box*
- POMS: Piezo-optomechanical Spectrometer
Theory and Modeling
More Info- Computational Nanoscience Software and Modeling Expertise*
- BLAST (Bridging Length/Timescales via Atomistic Simulation Toolkit)
- Dacapo
- Density-functional-based tight-binding (DFTB)
- FANTASTX (AI/ML Framework framework to determine atomistic-level structures from multi-modal experimental and theoretical data)
- GPaw, a real space, grid-based DFT-PAW code
- Ingrained
- MPI-based parallel versions of the nanophotonics
- Time-domain nanophotonics simulation package
- VASP, ab-initio molecular dynamics calculations
- Other specialized analysis software or modeling expertise
- CNM High Performance Computing Cluster (Carbon)*
Nanophotonics & Biofunctional Structures
More Info- Agilent 1260 Infinity II High Temperature GPC*
- Centrifuge
- Beckman Coulter Avanti J-E Centrifuge
- Beckman Coulter Optima L-100 XP Ultracentrifuge
- Synthesis
- Surface modification of nanoparticles
- Functionalization
- Quantum Dots
- Metal nanoparticles
- Metal oxide nanoparticles
- Raman spectroscopy
- Temperature-controlled stage
- Bench-top spectroscopy
- UV-Visible Absorption
- Emission (FLS1000 spectrofluorimeter)
- FTIR Absorption
- Circular Dichroism
- Transient absorption spectroscopy
- UV-Visible-Near IR probe
- Femtosecond-nanosecond probe
- THz probe
- Nanosecond-millisecond
- Cryostat
- Surface Preparation
- Harrick Plasma Cleaner
- UVO Surface Cleaner
- Autoclave
- Time-resolved emission spectroscopy (streak camera)
- TCSPC Microscopy (400-800 nm)
- Visible and near-IR TCSPC with streak camera
- Near-IR TCSPC with superconducting nanowire single photon detector
- Electron Paramagnetic Resonance
- Visible and near-IR microscopy
- Visible detection
- Near-IR detection
- Cryostat
- N9 Synthesis robot
- NOVA 600 Surface and Pore Size Analysis
- Prelude X Peptide Synthesizer
- Optical Microscope for 2D Stacking
- Isothermal Titration Calorimeter (ITC)
- GC-MS (Agilent 5975C Series GC/MSD)
- HPLC (Agilent 1260 LC System)
- ZetaSizer Nano, Malvern (particle size potential)
- Drop Shape Analysis Tool
- Solar simulator, Oriel
- Field Emission Scanning Electron Microscope, JEOL JSM-7500F
- Laser Scanning Confocal Microscope, Zeiss LSM 510 Meta
- Optical microscope, Zeiss Axio Imager Z1 M Upright
- Automated Thin Film Solution Processing Robot
- Ossila Slot-Die Coater
- General wet lab space for sample prep
- Rotary Evaporator
- Schlenk Lines
- Solution-Shearing Station
- Integrated Glove Box System
- Peptide Synthesizer
Quantum and Energy Materials
More Info- Electrical characterization
- associated high-sensitivity test systems
- Keithley 4200-SCS/F Semiconductor Parameter Analyzer
- Atomic Force Microscopes (ambient)
- Thermal analysis
- Magnetometry
- Physical vapor deposition, common loadlock is shared*
- Tube furnaces
- Lindberg/Blue M Mini-Mite 1"
- MTI-1600 2"
- STT-1600 2"
- UV-Vis-NIR Spectrometers
- Ultrahigh Vacuum Scanning Probe Microscopes (STM/AFM)
- VT-UHV-atomic force microscope/scanning tunneling microscope (AFM/STM; Omicron VT-AFM XA) (NST-SOP-086.6)*
- Optical UHV VT STM/AFM (NST-SOP-126.9)*
- Low temperature multimode scanning tunneling microscopy (LT-STM, Createc) (NST-SOP-196.2)*
- Omicron LT-STM (SOP 303)*
- Createc low temperature STM/qplus AFM with RF/optics (NST-SOP-322)*
- Synchrotron X-ray Scanning Tunneling Microscopy (B125, NST-SOP-288)
- SPM Tip Etching
- Unisoku 1300J, UHV mK-STM, 400 mK, 9-2-2 T (NST-SOP-339)*
- X-ray diffractometers
- Agilent Inductively Coupled Plasma Optical Emission spectroscopy (ICP-OES, Bldg 200)
- Bruker Vertex 70 FTIR with Hyperion Microscope (Building 200)
- CEM Blade Microwave Digestion System
- Langmuir-Blodgett, Kibron MicroTrough X (Building 200)
- Near Ambient Pressure X-Ray Photoelectron Spectroscopy*
- Rheometer, AntonPaar Physica MCR301
- Rheo-XPCS
- Spin Coater, Laurell WS-400, not for lithography resist work
- Synthesis Lab - inorganic crystals (Bldg 200)
- West-Bond Wire Bonder
- UHV Cryo SFM with 6T magnetic field, Omicron scanning tunneling microscope (NST-SOP-205)
- Electrochemical Workstation (BASi Epsilon)
Electron and X-ray Microscopy
More Info- Hard X-ray Nanoprobe*
- Chemical and Structural Nanoimaging
- Scanning Nanodiffraction
- Specimen preparation resources (not FIB)
- Cutting from bulk
- Grinding/polishing
- Dimpling
- Ion-milling
- Vacuum-coating with gold or carbon
- Data Analysis
- Image processing
- HRTEM image simulation
- Diffraction pattern simulation
- XEDS analysis (including spectrum images)
- EELS analysis (including spectrum images or EFTEM spectrum images)
- TFS Spectra 200*
- Probe corrected
- TEM imaging and diffraction
- STEM imaging (HAADF & DPC)
- 4D-STEM (EMPAD)
- XEDS, Super-X, 4SDD EDX system
- Lorentz TEM imaging
- Tomography
- Gatan GIF System
- Biprism-based holography
- Quantum Emitter Electron Nanomaterial Microscope QuEEN-M*
- Probe corrected STEM imaging (HAADF & DPC)
- 4D-STEM (EMPAD)
- Super-X, 2SDD EDS system
- Electrostatic Beam Blanker (ns pulser)
- Gatan GIF System (Dual EELS)
- Cathodoluminescence (CL)
- Ultrafast pulser (ps pulser)
- Hitachi S-4700-II SEM*
- SEI & BSE imaging (0.5-30 kV)
- XEDS mapping or spectrum imaging
- Field Emission Transmission Electron Microscope, JEOL JEM-2100F*
- TEM imaging and diffraction (200 kV)
- EFTEM imaging (200 kV)
- EELS (200 kV)
- XEDS
- Pump laser wavelengths: 343, 515, 1030, 325-450, 650-900, and 1200-2000 nm
- Tomography (200 kV)
- Special specimen holders
- Talos F200X (S)TEM*
- TEM imaging and diffraction (80, 120, & 200kV)
- STEM imaging (HAADF & BF; DF2, DF4, DPC, 80, 120, & 200 kV)
- EDS mapping (profiles and/or maps)
- Lorentz imaging (200 kV)
- Helios 5 CX Ga-FIB*
- TEM sample preparation
- Oxford EDS detector
- Oxford EBSD detector
- Cryo (LN2) stage
- 3D imaging
- Ultrafast Electron Microscopy (UEM)*
- Temporal resolution ca. 1 ps
- Electrical triggering
- Energy resolution ca 1 eV
- Imaging, diffraction, EELS & EFTEM
- Repetition rate: 10-500 kHz (fs laser), 1-100 kHz (ns laser)
- Spatial resolution ca. 1 nm
- Holders
- Cryo Sample Prep - Vitrobot
- FEI Quanta 400F (E)SEM*
- High-vacuum mode (P < 10-5 torr)
- Low-vacuum mode (P ~ 0.1-2 torr)
- ESEM mode (P ~ 2-20 torr)
- ESEM mode with a gas other than air or water vapor
- Peltier-cooled stage (T ~ 248-328 K)
- Heating stages (T < 1273 K or T < 1773 K)
- JEOL IT800HL SEM*
